TwinTurbo.NET: Nissan 300ZX forum - I would check connectivity between
njz
on May 01, 2012 at 12:49 PM
Stumble at low rpm, kinda stumped...continued
posted by Woody75 (Denver)
on May 01, 2012 at 11:13 AM
Components (PTU,Temp Sensor ect) back to the ECU (F1) to make sure it's not an intermittent harness problem like Hi resistance ground , short or open. What Year is the Z?
Woody75 (Denver)
11:13:44 05/01/12
I would check connectivity between -
njz
12:49:43 05/01/12
It's a 1994.
Woody75 (Denver)
12:59:37 05/01/12
Re: It's a 1994.
njz
13:32:43 05/01/12
Heres what I meant
Woody75 (Denver)
14:06:22 05/01/12
understood. Good luck. (n/m)
njz
14:12:02 05/01/12
When you do a power balance test....
MeatMan - 604Z.ca -
00:35:34 05/02/12
Probably a crazy idea, but you might check that the
not4resaleZ
12:53:42 05/01/12
They are correct. (n/m)
Woody75 (Denver)
12:57:50 05/01/12
how about the injector connectors? (n/m)
aliaZ
07:47:26 05/02/12
Yep, everything is correct. (n/m)
Woody75 (Denver)
12:31:10 05/02/12
Perhaps it's an air leak problem. When you give the car
doug8867
15:09:52 05/01/12
Already did a boost leak test.
Woody75 (Denver)
15:59:01 05/01/12
Did you check the VTC.
xpwarrior
16:22:03 05/01/12
Ahhh.... Thank you.
OverZealous (CT)
19:28:12 05/01/12
Checked. No issue or change. (n/m)
Woody75 (Denver)
22:06:19 05/01/12
Check the MAF.
MixManMash
19:44:03 05/01/12
MAF has been replaced. (n/m)
Woody75 (Denver)
22:06:48 05/01/12
Maybe it's bad fuel. Dump some STP gas treatment in it.
DVDBURN (MD)
21:11:13 05/01/12
Hes had this issue ever since he got the car.
Woody75 (Denver)
22:05:41 05/01/12
Well guys at this point we may never actually know.
Woody75 (Denver)
22:10:11 05/01/12
Random thought...
JonnyZ(SoCal)
03:58:28 05/02/12
Already been covered. (n/m)
Woody75 (Denver)
07:39:28 05/02/12
Unbalanced TB? (n/m)
nismo_boost31
13:01:37 05/02/12
Re: Stumble at low rpm, kinda stumped...continued
bbsalexaz
16:34:50 05/03/12
Yes, everything was tried one thing at time. (n/m)
Woody75 (Denver)
22:51:15 05/03/12
